3 members (ShopRag, dt235sd, 1 invisible),
359
Mod | | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | I have been using PPG K36 high build primer & DP epoxy primer on my cab. My local PPG dealer went out of business couple weeks ago & nearest one is 20 miles away. I have a DuPont dealer less than 2 miles away. Can I shoot DuPont urethane enamel directly over my PPG primers without reaction or just not be lazy and drive the 20 miles each way? | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | I've got NAPA's Martin Senour, Dupont , and PPG products on my truck in various ways. No problems yet! Been restoring it for 3 yrs now, just painted cab and front Sunday with PPG DBC base and NAPA clear.Looks great so far! | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | As long as there's nothing in the PPG products that would prevent proper adhesion (fisheye eliminator, etc.) of the Dupont paint you should be OK.
| | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | Thank you both for your replies. I have not put any top coats on yet, just epoxy & high build primer mixed as directed by tech sheets with no additives. | | |
