8 members (Gdads51, frogfarmer, Hotrod Lincoln, rfs56trk, JoeDude, Jon G, TexasA&M48Truck, dt235sd),
139
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 14 New Guy | | New Guy Joined: Jun 2011 Posts: 14 | Hi all, You are all great resources! I got my exhaust pipes remade locally. Sounds great now.
Next problem: Manual choke linkage to the carb.
The carburetor has a vertical up/down motion for the manual choke but the cable comes out in a horizontal manner. Sigh. I THINK the previous owner swapped out the ?original Quadrajet? for the Holley 4bbl that's on there now but there's no way to know when it was done. She's a real cold starter ;-) for sure.
Any thoughts or suggestions on how/what to hook this cable up CORRECTLY so the manual choke works? Thanks In Advance, Chris
PS - Pics to come. I'm busy raiding the local salvage yard for interior parts which my wife keeps asking me 'What's that for? Aren't you going to sell it next year?'
PPS - It's a 366ci in a 1971 C60 Short Dump and I still have to get a radiator overflow tank from somewhere and the 4 inch diameter breather hose for the air cleaner AND somehow the odometer cable (PITA because of the 2 speed rearend) AND the temp sender. Hey - at least the oil pressure, vacuum, and gas gauges work ! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 60 series didn't come with a Q-jet. It most likely came with the Holley thats on there but possiply with a large Roch. 2 barrel. If the holley is a manual choke it should have bracket & swivel for the cable. Put a photo in & one of us can probably recognize it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2011 Posts: 14 New Guy | | New Guy Joined: Jun 2011 Posts: 14 | Here's a link to a pic of the side of the carb. http://www.cozirepro.com/assetts/IMG_0220.jpgDifferent model than yours, SimS. (I know - the auto choke is still connected but it really is not working.) Looked up your suggested part and YES! the linkage parts are in the kit! Thanks Sims!
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | That diaphragm that is vertical is for the secondaries on the carb. The diaphragm in the front is the vacuum pull off for the choke. | | |
