Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Southerntruck, Otto Skorzeny), 130 guests, and 5 robots.
Topics128,281
Posts1,058,464
Members48,490
#761367 07/11/2011 1:31 AM
OK Mr Dunderhead here. On my 64 there is a rigged looking hotwire going from the hot side of the battery to what I believe is my horn relay (which has a wire going to the horn). A large & small wire run from there thru the firewall, another small wire goes to the square metal box below it with 4 prong connectors on it (i believe some one stated there ar no stupid questions). Why the hotwire & what is the larger metal box?
elmeyer44 #761373 07/11/2011 1:55 AM
The "box" should be the voltage regulator. Has the truck been converted to a modern type internally regulated alternator? The older alternator were externally regulated, just like the generators that preceded them. If it's been converted, that would explain the hot wore, as the horn relay usually got its heavy lead directly from the regulator, rather than the battery.
Bill Burmeister
LONGBOX55 #761379 07/11/2011 2:21 AM
Thanks. I will check the alternator soon. It is dark here now & have a heavy week ahead. Thanks for the quick reply.
Larry
elmeyer44 #761932 07/13/2011 1:56 AM
Longbox55
Received my shop manual today. The wire is supposed to be there. I replaced the rigged wire & neatened it up.
Larry
