0 members (),
80
0
Mod | | | Forums66 Topics128,050 Posts1,055,644 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 4 New Guy | | New Guy Joined: Dec 2003 Posts: 4 | The 235 was running rough. I rebuilt the Rochester B with a napa kit, Adjusted the float per the specs. 1-9/32" gap. I cleaned the carb with a spray carb cleaner (methanol). The engine is still running rough after the carb rebuild. I have to choke it to get t the engine started. The engine would not idle. I changed the plugs and reset the points. This helped a little. The engine will idle now. It seens to be trunning rich as at an idle the exhaust is gray. The engine sometimes pops on acceleration. Could it be timing or did i mis something in the carb rebuild? is there an easy way to clean the passage ways through the carb body? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Check for a vacuum leak, if your using a lot of choke it has to get air from somewhere. Look for an uncapped hose or a loose carburetor. | | |
