9 members (Bill Hanlon, TooMany2count, 66flea, Hotrod Lincoln, BC59, Charles in CA, Gdads51, 68ironhead, 1 invisible), 90 guests, and 3 robots.
Topics128,032
Posts1,055,519
Members48,425
#761121 07/10/2011 1:34 AM
So im trying to get the truck to run a bit smoother, when at idle and we give her some throttle she dies. i have no idea why and everybody ive asked has no idea...
What should i check? what am i looking for?
3B Offline
Hy Josh_51GMC, did you get that vacuum gauge yet??? When you say it "dies" do you mean it actually stops running, or does it hesitate and possibly backfire through the carb? You told us a while ago that you checked the carb and the accelerator pump was giving you a shot of fuel every time you worked the throttle, so leaning the mixture shouldn't be the problem. When you get the vacuum gauge put it on a manifold vacuum source and tell us what the readings are at idle and what they do when you attempt to rev it up.
3B #761169 07/10/2011 3:42 AM
yes i got the gauge, it reads 16.5 PSI idling and slowly varies down to in-between 7 and 3 before it actually dies. like stops running.
3B Offline
Hy Josh_51GMC, those readings indicate a plugged exhaust system, try dropping the exhaust pipe off and see how she runs and the gauge behaves
3B #761178 07/10/2011 4:35 AM
will do, would that be why when we have her at idle, theres a bit of a hissing noise?
If thats not it, what should i look for next?
3B Offline
Hy Josh_51GMC, one step at a time Josh, one step at a time.
3B #761187 07/10/2011 5:39 AM
haha alright, ill cut my exhaust off tomorrow, im pretty sure a couple rats made a nest in it when it was sitting for 30 years
3B, thank you so much! my entire exhaust system was plugged solid with grain from the farm!
here's a vid of her running and reving strong!
Thank you everybody who helped me get this far
3B Offline
Hy Josh_51GMC, you're welcome, that's good news. Now that you have it running, lets fix all the brakes next, okay?
3B #761318 07/10/2011 9:26 PM
haha sounds good to me, ill be making a new thread
