| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | So im trying to get the truck to run a bit smoother, when at idle and we give her some throttle she dies. i have no idea why and everybody ive asked has no idea...
What should i check? what am i looking for? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_51GMC, did you get that vacuum gauge yet??? When you say it "dies" do you mean it actually stops running, or does it hesitate and possibly backfire through the carb? You told us a while ago that you checked the carb and the accelerator pump was giving you a shot of fuel every time you worked the throttle, so leaning the mixture shouldn't be the problem. When you get the vacuum gauge put it on a manifold vacuum source and tell us what the readings are at idle and what they do when you attempt to rev it up. | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | yes i got the gauge, it reads 16.5 PSI idling and slowly varies down to in-between 7 and 3 before it actually dies. like stops running. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_51GMC, those readings indicate a plugged exhaust system, try dropping the exhaust pipe off and see how she runs and the gauge behaves | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | will do, would that be why when we have her at idle, theres a bit of a hissing noise?
If thats not it, what should i look for next?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_51GMC, one step at a time Josh, one step at a time. | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | haha alright, ill cut my exhaust off tomorrow, im pretty sure a couple rats made a nest in it when it was sitting for 30 years | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | 3B, thank you so much! my entire exhaust system was plugged solid with grain from the farm! here's a vid of her running and reving strong! Thank you everybody who helped me get this far
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_51GMC, you're welcome, that's good news. Now that you have it running, lets fix all the brakes next, okay? | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | haha sounds good to me, ill be making a new thread | | |
