0 members (), 146 guests, and 2 robots.
Topics128,162
Posts1,056,939
Members48,458
#760791 07/08/2011 8:22 PM
Hello, I just wanted to know how to hot wire my pickup. I bought the truck without keys, and I am getting ready to fire it up for the first time. Do I just remove the wires from the ignition switch, connect them together and push the foot starter? Also, to remove the ignition switch do I just loosen the 2 screws, twist and pull out?
Thank you
1952 GMC 150 3/4 ton 5 Window
3B Offline
Hy CheapThrills_52, connect a wire from the hot post on the starter to the coil input side, and remove the wire that was attached there, now step on the starter and she should start. Don't leave the wire connected when you're not trying to start/run the engine, hope that helps.
3B #760821 07/08/2011 10:07 PM
Ok thank you! I will give it a try.
I just thought of something. My battery is hooked up in reverse. The negative goes to the starter and the positive is grounded. So I put an alligator clip on the coil where the ignition wire goes and hook up the other side of wire to... ?
Thank you
gmc's are positive ground. just hook it up like 3B says to and you'll be fine.
Ok thanks guys!
would this apply to a 1957 chevy truck
1957 Chevy
235 Inline 6
SM420
http://i50.tinypic.com/2e36b5v.jpg
Yes, except negative ground.
