2 members (Dakota Bob, RLB),
136
Mod | | | Forums66 Topics128,282 Posts1,058,492 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 32 New Guy | | New Guy Joined: Mar 2011 Posts: 32 | can some one post a pic of the area where the fender meets the cab inside the wheel well..my new toy came with some corrosion issues and the way the previous owner overcame fender support was to weld a large bolt between the cab and the fender on the inside..lots of Mapp gas and a large hammer and alot of muscle later i have it free-the front clip is off and i need to identify the correct patch panels to purchase to make her well again..im thinking some kind of bar goes there like in the front of the wheel well-please assist! | | | | | Joined: Jul 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 90 | What series is it? A LCF is different from a normal Cab.
Cheers Dyna | | | | | Joined: Mar 2011 Posts: 32 New Guy | | New Guy Joined: Mar 2011 Posts: 32 | its a normal cab thank you | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you really need the assembly manual - at the bottom there's a bolt that threads into the bottom end of the brace on the inner side of the fender, and the piece on the cab that the bolt goes thru may have rotted away, or more likely the lower end of that brace on the fender rotted .... for patches I'd say you need the lower part of the brace [with captive nut] and probably the lower mounting bracket .... and likely the lower hinge pillar pocket where the drain is for the cowl vents .... there are also brace rods from the back of the wheel opening on the fender to the cab Bill | | | | | Joined: Mar 2011 Posts: 32 New Guy | | New Guy Joined: Mar 2011 Posts: 32 | thanks Bill thats exactely what i was thinking as well,,,was just looking for a pic to help me wrap my head around it. ill work it out,,im still some time away from where im putting in patches,,engine and brakes come first!!! | | |
