4 members (lumbersawyer, Hush, 2 invisible),
64
Mod | | | Forums66 Topics128,026 Posts1,055,407 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 35 New Guy | | New Guy Joined: May 2011 Posts: 35 | When I bought my 1952 3100 a few months ago, it had a crack in the driver's windshield panel. I have replacment glass on order and will have it installed by a local glass shop. Is it possible to just replace a single panel? The windshield rubber is in good shape so not sure if this is possible. All articles I've read on windshield replacement start with no glass in the truck. Just wondering if the broken panel could be removed, the seal worked out of one side and a new glass piece installed.
1952 3100
| | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Yes it can be done, had my passanger side window replaced about six months ago.
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
1952 3100
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I would check the other side for clouding on the edges. It probably wouldn't cost much more to replace both. Also, you might want to replace with tinted. I did and am quite pleased with what I got.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | How old is your existing glass? It may well be it's covered in tiny pits and scratches.(Normal wear and tear) Trust me if it is old you will notice it when a new glass is installed next to it.
One can be done but personally if I were replacing one half,I would go the whole nine yards and replace both. It wouldn't hurt to replace the rubber at the same time either...JMO
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Jock's right. In fact the most important part you will replace is the rubber. https://secure.steelerubber.com/
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Yup! There's nothin' worse than soggy carpets!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
