7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,028
Posts1,055,414
Members48,422
#760453 07/07/2011 11:37 AM
When I bought my 1952 3100 a few months ago, it had a crack in the driver's windshield panel. I have replacment glass on order and will have it installed by a local glass shop. Is it possible to just replace a single panel? The windshield rubber is in good shape so not sure if this is possible.
All articles I've read on windshield replacement start with no glass in the truck. Just wondering if the broken panel could be removed, the seal worked out of one side and a new glass piece installed.
1952 3100
Yes it can be done, had my passanger side window replaced about six months ago.
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Thanks Charley!
1952 3100
I would check the other side for clouding on the edges. It probably wouldn't cost much more to replace both. Also, you might want to replace with tinted. I did and am quite pleased with what I got.
~Jim
How old is your existing glass?
It may well be it's covered in tiny pits and scratches.(Normal wear and tear)
Trust me if it is old you will notice it when a new glass is installed next to it.
One can be done but personally if I were replacing one half,I would go the whole nine yards and replace both.
It wouldn't hurt to replace the rubber at the same time either...JMO
More pix on Flickr.
Jock's right. In fact the most important part you will replace is the rubber. https://secure.steelerubber.com/
~Jim
Yup! There's nothin' worse than soggy carpets! grin
More pix on Flickr.
