1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76045 04/07/2007 6:38 PM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | Does anyone have an opinion as to whether this modern type of Bendix booster would be compatible with the single master brake system that is OEM on a 53 1 ton? I can make a bracket if necessary, just wondering if this modern unit would make more sense than rebuilding the OEM that was on the truck; it does price-wise. Bendix 2512065 / 2508827 / 2515050 Ebay Item number: 260101629423 Darn, I messed up the link but I would appreciate the input. Don Bendix 2512065 / 2508827 / 2515050 Item number: 260101629423 | | |
#76046 04/07/2007 6:51 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the item - looks like the right critter - they haven't changed much over the years, and I know modern ones do work maybe you should call them, it's toll free! 800-489-9860 Bill | | |
#76047 04/08/2007 6:45 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Blacksmithdon, that hydrovac is just a modern simple version of the old piston with an outer seal hydrovac, this one uses a flexible diaphragm, and it is totally compatable with your system, hope that helps. | | |
#76048 04/08/2007 9:20 PM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | Thanks, I am going to pursue this a little furthur. | | |
