0 members (),
128
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | John Smith has put together a great tech tip that this group may enjoy. Taking all those pictures AND writing up all the details was probably more work than actually switching from disc brakes to power brakes!! It's all here for you to check out. Feel free to post any feedback, ask questions. We've linked the TT page here so John can add additional details if necessary. Thanks John! Peggy M
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Great write up, now if someone would just do it for a crossmember swap, lots less parts to hook up. and cheaper.
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Did I miss something? did I read too fast? The most important part? What spindles? what other parts do I use? This should be the first thing on the list of How to's in any TIP. Didn't look at all the pics, so if the info is there, it's too buried. What rotors? what booster? What year of donor truck? or what are the new part numbers? where did you get the parts?????????
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Alot of people have after market kits. I got my kit from CPP and it included the spindles, rotors, lines, tie rods, etc...was a complete kit except for the master cylinder. It also allows you to upgrade to the newer 73-87 style tie rods. I also purchased a spring/shock kit from them and will swap those out at the same time. I believe if your after a donar truck BARTAMOS you should look for a 73-87 chevy with the bolt pattern that your looking for I.E. 5 lug, 6 lug or 8 lug. | | |
