0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I have a 6 volt Delco Remy starter (model # 1107108) on my 52 chevy truck w/ the 216 engine. I recently had the starter rebuilt & it seems the drive gear does not mesh with the flywheel. Can anyone tell me how many teeth should be on the drive gear? Mine has 9? Thanks. Bob | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I have a #1107055 starter w/9 teeth and my flywheel has 139 teeth. Don't know if that helps. Do you have the old drive gear? Strange that it won't mesh now if it was OK before the rebuild.
Ed
| | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Thanks Ed, that helps a lot. I'm beginning to wonder if the starter is not the problem, but purhaps my engine locked up (but that doesn't make sense either, cause it was drivable just a couple months back). Bob | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bob, Wait to see if someone who knows about the 6v vs 12v "drive gear". I dimly recall postings about both having 9 "teeth" but they are different. 1938-55 starter drive 1955-59 starter drive Maybe ask the rebuilder what year starter drive he put in the starter? | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | The armature shaft diameter is bigger on the 6 volt starter, isn't it? I don't think a 12 volt starter drive will fit a 6 volt armature, even with a can of grease and a BFH! Jerry
| | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Thanks everyone. In my mind it's now official - I have the correct bendix, w/ 9 teeth (Tim, the pictures were helpful). So, I'm off to find what else is the problem (ring gear? babbitt bearings? oil pump? crappy truck that I should get rid of?). Bob | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | How about a few more details about the problem? Is the starter turning but not spinning the engine, or is the starter drive engaging and the flywheel refusing to turn? How about putting the transmission in high gear, and see if the engine turns when you push the truck? If not, something's locked up- - - -maybe a cylinder full of water or gasoline? Jerry
| | | | | Joined: Jul 2011 Posts: 36 New Guy | | New Guy Joined: Jul 2011 Posts: 36 | I had a problem with my starter bendix as well. Its a 6 volt starter, and a 12 volt system. It only takes a second to spin up the engine and starts right away. My problem was the snap ring on the armature had worn and came off. I had replaced it but it wasnt the exact type and when the bendix engaged it forced the cheapy snap ring off, again allowing the bendix to slide too far and it hung in the engaged position. So had to remove the starter again and found the right snap ring. Works fine now.
Billy | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | In my search for a new starter drive, FLAPS had a couple that were supposed to fit. They looked similar except the 9 tooth gear was smaller in diameter and I think they fit the pitch of the 12 volt flywheel. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | This was a confusing issue 50 years ago. My junk yard dog way of figuring out the difference the shaft on a 6 volt was more than 1/2" and a 12 volt less than 1/2". Both have 9 teeth. Not many numbers to remember that way. | | |
