5 members (Ranger, Peggy M, carbking, MNSmith, WICruiser), 97 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#759818 07/05/2011 12:34 AM
Wanting to know if the hubs brakes and backing plates from a 53 one ton will swap to a 49 one ton axle. Curently running huck type brakes and want to update to the later bendix brakes. Have both axles complete with the 49 having new king pins and tie rod ends and the 53 axle being fairly well worn but with good hubs drums and other brake parts. The huck brakes work fine but I'm changing the rear end to a later model with good working bendix brakes.
ttodd #760025 07/05/2011 8:58 PM
3B Offline
Hy ttodd, there is a bearing change in 53, and it also appears that the kingpins are different as well. Im not saying it's not doable, it just looks like it will be a challenge. Probably the simplest would be to rebuild the 53 axle and swap that in place, hope that helps.
3B #760073 07/05/2011 11:15 PM
Thanks for the reply, thats probably what I'll do. Someone might need the 49 axle.
Moderated by  Dusty53
