4 members (55shaker, Forty9, Jon G, BillCollins), 203 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
#759766 07/04/2011 10:22 PM
For a rookie like me, is it a fairly easy task to rebuild a Rochester carb on my 235?
Also, the truck has not run for about 10 years so I assume this should be done prior to even thinking about firing it up?
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
rochesters have got to be the simplest carb on earth. you can probably handle it. If not, don't touch anything else on your truck.
For a rookie like me, it was't too bad. Rebuild basically means take it apart, put it back together. Make sure you've got your cheat sheet that comes with the rebuild kit, or a seperate manual, whichever. If you run across any problems, post it in the appropriate forum, and you'll get help from plenty of people.
Prior to firing it up, be sure to get out the bad gas in the fuel lines and in your tank. Bad gas will muck up that freshly rebuilt carb of yours.
Dave Baird
1951 Chevy 3803
If you're comfortable wrenching on your truck, then you'll probably have no trouble. There are some great carb builders on this forum that can help you.
I used a kit from NAPA to rebuild my '54 Rochester B.
>>> Label and bag each piece as you remove it. You'll thank me when you start reassembling!
See the overview of the Rochester carb in the 1948-51 Chevrolet Truck Shop Manual ...
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0658.htm
Then follow the step-by-step instructions in the section titled "Major Service Operations."
You may also want to check info in Rochester Service Bulletins ...
http://chevy.oldcarmanualproject.com/carb/Rochester/index.htm
- Lonnie
My '54 3104
Thanks for the confirmation guys...especially Brokenhead... grin
Allan
1951 GMC 1/2-ton
Hi Allan! I rebuilt my carb following the instructions in these videos. I found the float was not anywhere close to being adjusted correctly, certainly there would have been issues with installing the carb as-is.
Teardown
Assembly
Assembly (with float adjustment)
If you want to get it clean and new looking, I suggest you make a home made soda blaster and blast away at the carb parts. Search the web for instructions on making a cheap yet affective soda blaster.
I've always used Berryman chem-dip carburetor and parts cleaner. chem-dip You can get it at any auto parts store,lasts a long time.Follow the directions on the can and all will be good.
Rodchesters are easy to rebuild,I always have to make notes about the two steel bb's inside,they are different in size.
Good Luck !
Tim
1951 3100 Chevrolet
Thanks for the tips...and the video links!
Allan
1951 GMC 1/2-ton
