0 members (), 47 guests, and 0 robots.
Topics128,050
Posts1,055,641
Whats the difference between the running board aprons on a 53 (and earlier) 3100 and the ones on a 54 3100?
If there is a difference can the earlier aprons be modified to work on a 54 3100?
Thanks in advance
Walt Williams
La Verkin, UT
Y
Y Offline
All I know is that the bed sits lower. The 54 frame doesn't have the kickup over the rear axle. I'll look at my 54 tomorrow and compare the aprons to my 53 and let you know. The 54 also doesn't use the wood blocks?
Y
Y Offline
Sorry, I took so long, computer problems. After checking my aprons out, I can't see any difference between the 53 & 54. I think GM modified the bedside panel when they made the change. Running boards and fenders interchange.
The running board aprons (and supports) on 1/2 ton trucks are different for 47-53 and 54/55.
