0 members (),
234
9
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Fresh rebuild on a '76 400: flat-top pistons, Lunati cam, Edelbrock manifold & 600 cfm carb, short headers & turbo mufflers. After initial firing & the usual ignition timing & carb tweaking, engine ran for about 20 minutes at 2000rpm with no smoke or apparent problems. It did get pretty warm, and popped the radiator cap on shutdown...I think I didn't have enough radiator or fan. Upon removal of the headers, I noticed that the entire exhaust path, all ports, was coated with a fine black soot. Plugs were the same. To me, this says rich fuel condition, but in the past I've always noticed some smoke or fuel smell. Any other thoughts? If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Edelbrock has a habit of over-jetting their carbs to avoid burning holes in pistons from a lean mixture. You'll probably need to go down a size or two on jets once the vehicle gets on the road. That will also help out in the power range, as rich-running engines don't make very good power. Wait until you get a few road miles on before tinkering with the mixture, as you might find the engine exhibits different running characteristics under load, but I've found on numerous dyno runs that Edelbrocks need some fine-tuning to get the best output. Most people way over-carburete engines (750 CFM on a 305 engine, for instance) so Edelbrock jets 'em rich from the factory to try to make their carbs idiot-proof. Jerry
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Makes sense, Jerry. I'm pretty sure I'm not over-carb'd with that little 600, but I can see why Ededlbrock would over-jet...better safe than sorry. Engine is still on the stand, so I think I'll run it some more to check some other things and try more rpm's and a different radiator. Thanks for your input.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
