| | | Forums66 Topics128,084 Posts1,056,334 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Working on my task force door to repair rust damage. I cut out a section of the inner door that had significant pitting and pin holes. The outer skin and lip look good with the exception of a dime sized area with pin holes. I welded up the pin holes. Would like to use a POR 15 or something similar to coat the inside of the skin before installing the inner patch. Will this hold up? Please advise. | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | I'm no expert but I'd say yes, should be fine. I brushed on epoxy primer nice and thick on the inside of mine. Darren | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ditto on that, but also make sure the drain holes are clear at the bottom - the reason the doors rust in the first place is those drains get plugged with dirt and then water getting in around the window turns it to corrosive sludge
Bill | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Thanks for the response. I have a little work left to do to fill those pin holes. Shined a light and could see some tiny holes. Also, raising that pinched lip is a bugger. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Speaking of metal repair and southern md. Maybe I should come by for a consultation. And maybe I should bring by my tailgate (62 C-10)? California MD. Welcome to Stovebolt. HB | | |
