4 members (TUTS 59, PAUL Berardi, 68ironhead, Peggy M), 120 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
#759353 07/03/2011 1:27 AM
so I am welding in some patch panels, after grinding down weld There are little pin holes do I need to worry about those, I tried welding in some but sometimes a make the hole bigger
thx
41 chev #759371 07/03/2011 3:19 AM
Personally, I would weld them in. Try turning the heat down a little on the welder.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Alan's 57 #759416 07/03/2011 1:10 PM
Ex Hall Monitor
Ex Hall Monitor
If the pin holes go all the way through and the back is exposed to the elements they should be filled. My concern with welding them is I don't know how many you have. Putting too much heat in a panel can create warping issues. I'm not familiar with all of the modern materials available but there may be some sort of an epoxy product that could seal the holes without re-welding. Again, if the holes are exposed to the elements on the inside (wheel well, fender, etc.) make sure both sides are filled to keep the rust monsters from inhabiting them.
Tiny #759419 07/03/2011 1:34 PM
You could also back up your welding with a chunk of copper to absorb the heat. Flatten a piece of copper pipe and clamp it behind your weld. I have a 3" square piece of 1/4" I use. And be sure to use gloves after you unclamp and it falls to the floor. Don't ask me how I know! Have fun and good luck
Dan
Chev4t6 #759493 07/03/2011 6:43 PM
Thanks for the help guys, the patch panel is on the cab, so pin holes on the cab no big deal but on panels where moisture can get to both sides need to be filled
