7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible),
122
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | My truck has a 235, 3spd. column shift and I would like to put on a safety switch so it won't start in gear. If someone could point me in the right direction it would be greatly appreciated.
thanks | | | | | Joined: Aug 2003 Posts: 65 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 65 | You'll have to rig a switch on the clutch pedal or linkage that will break current flow to the starter solenoid until the clutch is disengaged. Hope this helps.
51 Chevrolet Canopy Express 02 K25 Duramax Crew Cab
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A safety switch that would have to complete a circuit when TWO levers are in the neutral position is possible but not easy. All later model standard trans use the clutch switch where the clutch pedal has to be down near the floor for the starter to engage.
Evan
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Nash used to use a stomp-start type switch operated by a tab on the clutch pedal. As the pedal came close to the floorboard, the last inch or so of pedal travel actuated the starter solenoid. I think there was also a vacuum-operated safety switch in the carburetor that prevented the solenoid from engaging with the engine running Jerry
