9 members (TUTS 59, cmayna, Rusty Heaps, 49choptop, treegrower, Wickedbass, UtahYork, Gray_Ghost, tclederman),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members, I have a 54 3100 with a key starter, I have just put everything back together for a start-up. My starter only engages every 5-6 turns of the key.... it Vrrrrooms each time and then engages and turns over like normal. Is this the solenoid, or starter or both? How can I see which one is bad? Can the local FLAPS bench test it and see ? Or did I install wrong and the alignment is off. Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | spinning without engaging is the starter, if the solenoid were bad it would just click
Bill | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Change the starter drive. There's a one-way clutch in it that appears to be slipping intermittently instead of turning the flywheel. It's a pretty common failure of a worn-out starter drive. (sometimes called a "Bendix", which it isn't) Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Change the starter drive. There's a one-way clutch in it that appears to be slipping intermittently instead of turning the flywheel. It's a pretty common failure of a worn-out starter drive. (sometimes called a "Bendix", which it isn't) Jerry I think that "Starter Drive" was called an overrunning clutch by DELCO-REMY? | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Got her fixed boys, starts right up now. Thanks..It was the starter shaft.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not sure what your mean "it was the starter shaft"??? Could you elaborate for us, someone else might run into to same problem.
DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Denny: It was as Tim explained in the above post. Thanks | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Denny, I know I called it a bendix on my Harleys...But this is a new game for me...so i was told it was a starter Drive/shaft..whom am I to disagree...besides IT's fixed whatever it is.. HooRaa Thanks | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | A starter "Bendix" (which is a brand name, BTW) has a ratcheting tooth setup instead of an overruning clutch, and a very coarse thread on the pinion gear which engages it due to inertia when the starter shaft starts to spin. There is no solenoid action involved in making the gears mesh, just starter armature rotation. The Delco-Remy style starter drive has an overruning clutch as part of its features, but there are several other parts to the drive assembly. The gear on a Delco drive is engaged into the flywheel ring gear by solenoid action before the starter armature starts to turn.
Engines which had a habit of firing a cylinder or two without actually beginning to run had a habit of disengaging a Bendix drive prematurely, necessitating repeated efforts at starting. An example of such an engine would be the Chrysler Corporation flathead sixes, and some of the early Ford overhead valve V-8's, the 239 and 292. These engines used a "follow-through" Bendix which remained engaged until the flywheel spun through one or two revolutions after starting. Heavy-duty Diesel engine starters use a variety of very rugged starter drives such as the Dyer Drive, or a Sprag clutch, or a couple of other high-torque designs. Jerry
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny, Check out this manual on Keith Hardy's website: http://chevy.oldcarmanualproject.com/electrical/49dr324/index.htmIt shows Delco-Remy starters that use Bendix Drives, Over-Running Clutch Drives (like our foot-actuated starters), and Dyer Drives (I have never taken one apart but I think I have one). | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Jerry old buddy, when did you become a "Purist" I thought there were only a few of those around here on the forum. Oh I know technically there are several difference types of starter drives in use and I know technically what we have on our Stovebolts technically isn't a "Bendix" drive. But my point was that 99% of us still call it a Bendix and if we walk into our FLAPS and ask for a Bendix drive the dude or dudette behind the counter isn't gonna have any problem understanding what we want. I think a trademark such as "Bendix" has pretty much been generalized by anybody in the industry as a term for any over running starter drive in use today. Much as Bakelite is to Phenolic or Otis is to Escalator. Yep, downloaded all that years ago Tim, its in my reference piles somewhere, but as I said, in spite of all that, I’ll without a doubt still gonna be calling an overrunning clutch drive a Bendix, it‘s hard to change 69 years of habits. Besides, things been way to quiet around here this summer and it’s a good way to get Jerry’s dander up. Sooomebody’s gotta stur the pot once in a while! Denny Graham Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Denny, 40+ years of teaching knotheaded high school kids to use the right language when describing a part makes me drop into that lecture almost without thinking about it. Tools are another pet peeve- - - -"Gimme a flathead screwdriver" got this little spiel- - - -"A flathead is a Ford engine they quit making in 1953. Do you want a "common" screwdriver, or maybe a "cabinet" screwdriver?" Some kids finally got the message, and they're now the business owners and shop foremen, and the rest of them are pushing parts or working at Jiffy Lube, if they're in the business at all. I used to tell the kids if you don't have enough intelligence to fix cars, you can always become a doctor or a lawyer, or pick some other job that requires less attention to detail! Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So that's why I never made it in business! But I was a good greaser, Chevy parts man, now I did get the Doctors autograph down, but never could stand the sight of blood, lawyers and used car salesmen I bundle togeather and I never was very good at selling cars. Think we bout beat this one to death dint we????
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Statistically, a doctor's first diagnosis for a new patient is correct 40% of the time. His second guess only brings his average up to 60%! He only has two models to work on, and they haven't changed any of the systems in a few thousand years! He gets paid whether or not his treatment succeeds, and he gets to bury his mistakes! Run an auto repair shop to those averages, and we'd be out of business in a couple of months! If I could fix it right the first time about 95% of the time, I made money. Let the comeback rate get up to 10%, and I'd have a rough time surviving! I think I made the wrong career choice 50 years ago! Jerry
