5 members (55shaker, Charles in CA, JW51, Southerntruck, Gray_Ghost), 100 guests, and 1 robot.
Topics128,052
Posts1,055,725
#75897 04/03/2007 12:46 PM
I'm putting .040 LPG pistons in my 292, as well as a low-end cam. Due to financial constraints, I'm not able to change my intake or exhaust until next winter. Other than unrealized potential, are there any real problems with this?
Thanks for any help,
Jason
Your lack of preparation is not my emergency
Sounds like you're just cleaning up the cylinders and want a little more grunt. I would think that you will do ok with the stock intake/exhaust system. Of coure, all improvements over stock hopefully add to performance but your 292 already has the rep. for low end power. Just remember, "There is no substitute for cubic inches except cubic money".
I've never heard that one, but I'll put it on the wall next to "Fast. Pretty. Cheap. Pick two." lol I kow I want to open the breathing, but money tells me I have to wait. I just wanna make sure I won't mess anything up if I do the guts now but not the intake and exhaust.
Jason
Well "when in doubt, bore it out" but it sounds like your already doing that wink
58' 3200 235 3-speed/OD
Riding in the Passing Lane
It will work good the way it is but the 292 has a horrible stock exhaust manifold unless you have one from a 1 1/2 ton up. It needs more carb. to get it,s full potential. The 292 came with a larger throat carb. but most of them have been replaced with the smaller carb.
1972 Chevy c10 Cheyenne Super
#75902 04/03/2007 10:05 PM
I'm prepared not to realize the potential until I open up the breathing. I just want to make sure I won't hurt anything by using the crappy stock intake and exhaust.
Thanks for all the help
#75903 04/03/2007 11:49 PM
mabey you should let me "borrow" the lpg pistons till next winter. grin
#75904 04/04/2007 12:19 AM
Only if you promise to "play nice" with them.
#75905 04/04/2007 11:17 PM
oh, i would.
