| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75897 04/03/2007 12:46 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I'm putting .040 LPG pistons in my 292, as well as a low-end cam. Due to financial constraints, I'm not able to change my intake or exhaust until next winter. Other than unrealized potential, are there any real problems with this?
Thanks for any help,
Jason
Your lack of preparation is not my emergency
#75898 04/03/2007 1:20 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Sounds like you're just cleaning up the cylinders and want a little more grunt. I would think that you will do ok with the stock intake/exhaust system. Of coure, all improvements over stock hopefully add to performance but your 292 already has the rep. for low end power. Just remember, "There is no substitute for cubic inches except cubic money".
#75899 04/03/2007 1:41 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I've never heard that one, but I'll put it on the wall next to "Fast. Pretty. Cheap. Pick two." lol I kow I want to open the breathing, but money tells me I have to wait. I just wanna make sure I won't mess anything up if I do the guts now but not the intake and exhaust.
Jason
#75900 04/03/2007 6:16 PM | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Well "when in doubt, bore it out" but it sounds like your already doing that
58' 3200 235 3-speed/OD
#75901 04/03/2007 9:54 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It will work good the way it is but the 292 has a horrible stock exhaust manifold unless you have one from a 1 1/2 ton up. It needs more carb. to get it,s full potential. The 292 came with a larger throat carb. but most of them have been replaced with the smaller carb. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#75902 04/03/2007 10:05 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I'm prepared not to realize the potential until I open up the breathing. I just want to make sure I won't hurt anything by using the crappy stock intake and exhaust.
Thanks for all the help
#75903 04/03/2007 11:49 PM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | mabey you should let me "borrow" the lpg pistons till next winter.  | | |
#75904 04/04/2007 12:19 AM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Only if you promise to "play nice" with them.
#75905 04/04/2007 11:17 PM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | | | |
