10 members (68ironhead, Wally / Montana, 3B, Gdads51, Bill Hanlon, Gray_Ghost, Rusted Nut, Shade Baby, Pre '68 Dave, Otto Skorzeny),
162
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,104 Posts1,056,197 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: I disconnected my parking brake to bleed my new brake system. I painted and re-installed parking brake Parts ( rod and bars). Now the brake will not stay on...I push with my foot but the pinch bar doesn't grab the curved bar that goes thru the fire wall/floor ? I have no clue why ? Any suggestions..I did add floor pad and carpet,but I checked to make sure it wasn't binding... Thanks | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It's a pretty simple set-up there. You being there with eyes on it would be best to figure it out what it's doing unless someone here can relate. I would pull the carpet etc. back and see if that helps. Also check your spring.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jimmi, I too have had similar problems. Painting the radiused brake arm seemed to aggravate the problem for me. The flat 'pinch bar' can be sharpened up with a file to give more bite as well(that obviously requires removing it again) These wear over the decades and loose their edge. I also stretched the spring a little to give more pre-load on the flat bar.
Our annual inspection over here demands a working park brake,so mine will have to work......gulp!
Might be worth a try
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | I'll give it a try..Thanks | | |
