2 members (Hotrod Lincoln, Gray_Ghost), 95 guests, and 0 robots.
Topics128,051
Posts1,055,732
#75883 04/03/2007 3:39 AM
V
V Offline
The speed-o-meter in the 2-ton truck is not working. I removed the adapter and hooked up the cable directly to the gauge. It works now. My question is I have not seen how the 2 speed adapter mounts under the dash behind the speed-o-meter. Where can I find direction for installing the adapter correctly?
Thanks again.
#75884 04/03/2007 4:45 PM
Well, since no one else has posted an answer here I've got a couple of questions. I've never seen an adapter that mounts to the speedometer. Are you sure that's where it goes and not on the transmission end? And, if the speedometer is working without the adapter, do you need it at all?
#75885 04/03/2007 5:04 PM
Waldo - the speedo will work without the adaptor, but won't read correctly on one of the rear gear speeds .... but then who cares if it's not a daily driver grin
I've got one around someplace that I took off a TF truck - I think it's 2 speed rear was vacuum, but not sure
#75886 04/03/2007 8:41 PM
I have the 2-speed adapter thats mounted right to the back of my speedo for an ele4ctric shift rear end. Luckily mine works great so makes life easier. if I recall right tho, the one I have wont give correct speed in high gear, only low.
Look up a company called Spedomerter Solutions. they have been very helpful in my dealings with them, can even make custom cables (I have the 1/8" square drive on the speedo, and 3/16" keyed drive on the trans, FUN!). Worth a shot if you need to have the adapter looked at.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
#75887 04/03/2007 9:09 PM
V
V Offline
Waldo53: Here is what it looks like: http://rides.webshots.com/photo/2149599920080243953rzucGa
As for the question about do I need it? I'm trying to keep it original if possible. But I don't think it is really necessary for the driving we'll do with the truck.
Rd58: I agree it works fine without the adapter but I really want it to be as Chevy designed and built it in 1951. I might not get my way, but I'm not done with it yet!
So I still do not know how the thing mounts behind the dash.
FYI: I started this post before Freq2002 posted but I had to go to a 911 emergency before I could post it.
#75888 04/03/2007 11:18 PM
Great pic! So this thing actually changes ratios when you shift the axle...A great place to get an education here. All I've ever seen is the S-W ones that have a constant ratio & usually attach to the trans. If it bolts together like the others, you may take it apart & find a gear is loose on its shaft. In the S-W ones, they're just a light press fit & at a truck shop they'll usually have a drawer full of gears, shafts, & small parts to repair & re-calibrate them. Possible the parts will interchange into yours. Doug
#75889 04/04/2007 12:47 AM
O.K., I get it now! That's pretty neat. Hope you get it working.
#75890 04/05/2007 1:45 AM
V
V Offline
I'm still trying to figure out how this thing mounts to the rear of the speedometer. Anyone who has one of these things (in a 2 speed rearend) have a picture or an instruction guide?
#75891 04/05/2007 2:34 PM
In your pic I assume the 'open' barrel end facing the camera is the end that goes on the speedo & the opp. end w/male threads, the nut on the cable end attaches to it. Looks very similar to a standard S-W adapt. Looks like it splits in the middle for gear changes & has some extra threaded holes on top & bott. to mount the vac. can & linkage. Clean it up & take some pics of the other sides please. Doug
#75892 04/05/2007 11:52 PM
V
V Offline
I'll shoot those pictures and get them out for viewing. Thanks for the help.
#75893 04/06/2007 8:57 AM
Ok... the open end (facing camera) threads onto the rear of the speedo...(do NOT lose the small 1 inch piece of speedo cable that goes tween the adapter and the speedo).. and the speedo cable threads onto the other end.... Now for shifting the adapter.... you need a intertie rod that goes between the adapter and the under-dash 2-speed shifter....... Also, after you get the rod installed, you then have to go back and tighten the set-screw where the adapter attaches to the rear of the speedo... to lock everything in it's proper place.....
Basicly the same as on my 48 and 49's
Michael
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#75894 04/06/2007 11:31 AM
V
V Offline
I think you have found my problem! I do not have the 1" piece of speedometer cable. I think that is why it doesn't spin the speedometer gauge when my adapter was installed. Note: I just looked at the adapter and a picture of the rear of the gauge and that is exactly the problem... Thanks.
