1 members (lumbersawyer), 84 guests, and 1 robot.
Topics128,055
Posts1,055,782
I have been having problems with my 1953, Chevy 3100 with a 216 Engine. It starts fine and revs fine while in neutral. Once I drive it it seems to bog down. It feels like it's flooding, I have to be very light on the gas to get it to drive. After about 5 minutes or so it will stall and not restart. I read a post that this might be attributed to a bad distributor condenser so I ordered one. I can't seem to find where it's supposed to go. Any input?
Thanks in advance.
Should be inside the distributor cap along with the points. Should be mounted with a screw and the wire going to the point set.
I would be think more about a bad coil if I were looking for an electrical cause like that.
1951 1 Ton Completed
