9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman), 93 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
How do you remove the felt/metal seals around the door windows? What are those seals called?
Lee
they're called [felt] window channels - the top and back are one piece with a flexible metal core, just rip it all out, the front [on division bar] you have to cut/scrape out the felt and glue in replacement felt, or get a new division bar with the rigid metal channel factory finished - see here near the bottom
also, if yours is original there will be small clips that stab into the channel backside to hold it tight, do not lose those, they're not available repro
Thanks Bill
Lee
