7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible), 97 guests, and 8 robots.
Topics128,106
Posts1,056,213
Members48,436
#758428 06/29/2011 4:52 AM
Members:
I disconnected my parking brake to bleed my new brake system. I painted and re-installed parking brake Parts ( rod and bars). Now the brake will not stay on...I push with my foot but the pinch bar doesn't grab the curved bar that goes thru the fire wall/floor ? I have no clue why ? Any suggestions..I did add floor pad and carpet,but I checked to make sure it wasn't binding...
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
It's a pretty simple set-up there. You being there with eyes on it would be best to figure it out what it's doing unless someone here can relate. I would pull the carpet etc. back and see if that helps. Also check your spring.
~Jim
Jimmi, I too have had similar problems.
Painting the radiused brake arm seemed to aggravate the problem for me.
The flat 'pinch bar' can be sharpened up with a file to give more bite as well(that obviously requires removing it again)
These wear over the decades and loose their edge.
I also stretched the spring a little to give more pre-load on the flat bar.
Our annual inspection over here demands a working park brake,so mine will have to work......gulp!
Might be worth a try
More pix on Flickr.
I'll give it a try..Thanks
Jimmi V.
