3 members (MNSmith, Otto Skorzeny, 1 invisible),
155
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75808 04/01/2007 5:02 PM | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | hi all
i need some help with installing the distributor into my 261, i had a photo of the firing order of inline six's before and it showed the dist and engine with wire diagram ect ect....
the oil pump orientation to the distributor cam ect ect,,,, can someone help me get thru this area...
thanks jeff | | |
#75809 04/01/2007 5:32 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It goes something like this: Your cylinders are number front to back, 1 to 6. The distributor turns clockwise. In the usual layout, #1 on the cap sits pointing straight out sideways from the passengers side of the cap. The firing order is 1 5 3 6 2 4. So, rotate the crank until the timing mark, I presume on the flywheel, is lined up with the pointer. At this point #6 intake should be starting to open and #1s valves are closed. If #1 intake is opening, you need to rotate the motor another revolution. Then insert the distributor, with the rotor pointing to the #1 position. The bottom of the distributor shaft looks like a large slot screwdriver. That fits into a slot in the oil pump. Afterwards, put the number 1 wire on from cap to plug and then go around the circle and install the rest. | | |
#75810 04/01/2007 6:13 PM | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | i was looking down the distributor hole and the slot was not pointing in the right direction, see i had rotaded the crankshaft to #1 tdc, grabbed the distributor to put it in and the slot was wrong, and the rotor was pointing wrong,
so i am guessing that now after a lil research that i need to have #1 tdc and take a long screwdriver and turn the oil pump till the slot is in the right areaand drop the dist shaft in...
jeff | | |
#75811 04/02/2007 4:55 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | | | |
#75812 04/03/2007 12:49 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Also, since the gears of the distributor and cam are helical, the slot won't line up exactly where you think it does, so be prepared to experiment a bit.
#75813 04/03/2007 2:00 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | superpieboy,
If you follow the advice above, you'll be in business in no time. It's perfectly fine to stick the distributor in and let #1 plug wire fall where it may! The important thing is to seat the oil pump drive tang in the slot. If the distributor doesn't drop down all the way to the little collar, it isn't seated in the oil pump.
Stuart | | |
#75814 04/05/2007 2:26 AM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | 4 on the Floor is right about the cam alignment...if I remember correctly, you will need to rotate the distributor clockwise just past the point that you want it to line up and the distributor gear will line up with the cam gear. Also, if you have an extra distributor laying around, you can pull the shaft off of it and chuck it up into a drill and use it to prime your oil pump. I don't know if leaving the distributor gear on the shaft will allow you to spin the engine. Haven't tried that one, maybe someone else can sound off on whether or not it is a good idea. Good luck...the 261 is a good motor.
Whad you do?!?
Shane 1953 Chevrolet 3600
#75815 04/06/2007 9:09 AM | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | I may be showing age...as well as being NON-politically correct...lol..
But I learned six cyc firing order as "153624" or??? too young....too old.... just right..... 15 36 24
Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
