6 members (Southerntruck, dt235sd, Gdads51, GMCJammer51, NJC, John L.), 113 guests, and 3 robots.
Topics128,091
Posts1,056,392
Members48,442
I've ordered rear shocks for my standard half ton and twice they've been too short. I measure 24 inches from the lower mount to the upper mount center to center with the rear diff off the ground. Is this the correct distance or is my my truck messed up?
I've got 20 3/8" hooking tape on top mount to center of stud on bottom. I have a '52 3100(1/2 ton). Nothing in bed, sitting on the ground, not "jacked up". LMC part #34-2401
'52 3100 "once a Marine, always a Marine!!
Thanks Panhead. I'll recheck my measures but I think the bottom shock studs are bolted to the wrong side of the axle. They should be in front of the axle, not behind it.
Monroe 33049 fit my unmodified '52 1/2 ton and have seen the same number come up several times over the years from others. Getting them from a FLAPS rather than a usual suspect old truck parts vendor should be cheaper.
You Tube
Curt
Does the Monroe shocks you mentioned have a post or hole for a bolt on the bottom? I want to use tube shocks on my '48 instead of the knee action ones, and the mounts I have require a post on the bottom, but anything can be modified.
Originally Posted by bowtiefan
Curt
Yup. The lower mount looks like this:
http://secure.oldchevytrucks.com/SHOCK-MOUNT-LOWER-REAR-1950-1955/productinfo/MES135/
And the top one for reference:
http://secure.oldchevytrucks.com/SHOCK-MOUNT-UPPER-1950-1955/productinfo/MES134/
You Tube
