5 members (3B, 68ironhead, MickeyP, Gib70, 1 invisible), 125 guests, and 1 robot.
Topics128,050
Posts1,055,648
#757934 06/27/2011 2:53 PM
Just wondering if any one has experience with the
"engine run-on" condition as described in the MSD 6A
manual. This is where the presence of residual voltage after the engine is switched off keeps the engine running.
I have an internally regulated GM alternator and MSD supplies a diode to be installed at the alternator in order to prevent the MSD from being "back-fed" with even minor voltage when you turn off the key...
I'm going to install that diode, but was wondering if anyone else has experience with this....? and, did the little diode do the trick?
mike
Do as MSD suggests,it'll fix it.
Oh, Yeah!
That little tiny diode fixed the problem.....
took me longer to find it, than it did to put it in!
Thanks BC52
mike
Had the same problem on my "62", alternator exciter wire feeding back thru the ignition switch. Diode from Radio Shack on this wire with arrow pointed toward alternator.
