1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#758014 06/27/2011 8:57 PM
Does anyone know if a Carter Y-F is a direct bolt on replacement for a W1 on a 216? Will throttle, choke, etc. fasten same way or require changes? Thanks, Ken
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=727568&page=1
check the list Carb King Provided above
Im running a yf 787s on a 216 manifold.
DADS50 #758279 06/28/2011 8:26 PM
Thanks, that's an interesting thread with good info. Turns out the carb I have is apparently a 1949 vintage which somebody swapped in long ago!
