1 members (LAROKE),
36
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I'm converting the foot start on my 58 Viking with a 261 to a to a key start. I replaced the original starter with a starter that has an electric solenoid. The solenoid has 3 connections, R, S and battery. I have a basic ignition switch with battery, ignition, acss and a connection in the center. On the solenoid one wire connects the R to the positive side of the coil. The S connects to the center stud on the ignition switch. There is a second connection that comes of of the R terminal on the solenoid and a second connection that comes from the battery connection. Do these connect to the ignition and battery on the switch? I'm not concerned with the acc on the switch. Feel free to add to or correct anything I've written. I've seen wiring mistakes get ugly in a hurry. Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you'll need a different ignition switch [or an added push button] for a solenoid starting setup, the foot start switch won't do it, no 'start' position .... I'd suggest getting the V8 key start switch would be easiest
Bill | | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I got a generic ignition switch from the auto parts store with a start position. I want to make sure it's wired correctly before I hook up a battery. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I'm using a push button switch from a modern dump truck,i have found one that fits up into the original rubber boot that was mounted on the floor.My'n is a 54 with a 350- v8 but i think this would work with any electric starter. You can use a wire with gator clips to check where to place the switch in the wiring. Good luck
layback
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I am using a starter switch from a 58-59 in my 48. It has the key start. I have a 216 from a 52 chevy car with the key start solenoid. This setup works fine.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Dennis..are you too lazy to stomp? LOL
It is a good stress reliever. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Yes. Lazy. And forgetful.
