7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
I have a 216 with a completely rebuilt head. Have a possible crankshaft problem, so looking at swapping to a 235. Can I put the 216 head on a 235 block rather than rebuilding the 235 head (if needed)?
No.
Only 1941-53 235 blocks with 15 head bolts.
So up to 53 was still the babbitt splash motors with solid lifters? When did the pressurized 235 with hydralic lifters come out. I think it started with the automatic sedan.
The first 235 with full-pressure lubrication to all bearings, insert rod bearings, and aluminum pistons came in the 1953 passenger cars with Powerglide. The 1953 cars with the manual transmission and trucks with a 235 came with the spun babbitt rod bearings, low-pressure lubrication, and cast iron pistons, I believe that all of the 1953 235s had the 18-bolt heads. I know that the passenger car engines were 18 bolts, and the parts manual shows that the 235 truck engines were the same. The 1953 216s in trucks and the sedan delivery were the same as the previous 216s, with 15-bolt heats, spun babbitt rod bearings, cast iron pistons, etc.
Note that babbitt metal was still the bearing material in the precision-insert bearings in the high-pressure Powergide 235 engines in the 1953 cars. . The babbitt metal in the low-pressure 235s was described as spun, or "centrifugally- cast," and bonded to the rod and cap.
