6 members (MickeyP, Hotrod Lincoln, Nick in Manitou, KingG, 2 invisible), 108 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#757165 06/24/2011 7:42 AM
Hello,
I have a 235 Engine out of a mid 50's cars that I am trying to swap into my 1946 Stylemaster. Its been nothing but problems trying to do. My most current issue was with the intake/exhaust manifold. I thought my 216 was a direct swap with my 235 only to realize the 235 ports are much larger than the 216's. I am looking for a Downdraft manifold that I can run on my 235. Then original one on the motor bends to the right and will not mate up with my exhaust system. My only other option seems to be a three carb manifold which I am not intersted in doing.
Second question. My motor mounts were so bad when I pulled the engine out the disintigrated. I bought new mounts but can't seem to figure out how they fit inbetween. Does anyone have any pictures of a front mount 216/235 in a 40's car.
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder
1971 Chevelle SS
1995 Monte Carlo Z34
2005 Corvette Z51
Danspeed1 #757172 06/24/2011 11:15 AM
I will address your manifold problems. Use the manifold from your 216. One of our members here, Pre68Dave, makes adapter rings just for this situation. They replace the alignment rings used between the intake manifold and the head.
1951 1 Ton Completed
I see someone also has these rings on ebay.
Here is a Link to some pictures. #14 shows pass front mounts.
My Blog
Yea but shouldn't I be concerned about the small port size choking the engine?
DG
1971 Chevelle SS
2005 Corvette Z51
H Online: Content
If anything, the small ports and smaller-venturi carburetor will make the engine more responsive at low to moderate speeds. You'll lose a little top-end horsepower and RPM, but unless you're planning to run full throttle most of the time, you're not likely to see a major loss of performance. The carburetor might need to be re-jetted slightly leaner to compensate for the higher velocity through the venturi at any specific RPM.
I ordered the adapters for the intake however I just realized the Carb on my 235 has a larger spread than the one on my 216. My 235 carb is new my 216 one is shot. What can I do?
DG
1971 Chevelle SS
2005 Corvette Z51
Take the base plate off the 216 carb and it will bolt right up to the bottom of the 235 carb. Then the holes will line up with the 216 manafold. I did it with mine and it works fine.
'52 3100 "once a Marine, always a Marine!!
