8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75719 03/30/2007 5:23 PM | Joined: Jan 2004 Posts: 43 Junior Member | | Junior Member Joined: Jan 2004 Posts: 43 | Here I go again. I thought I'd try a 2004r behind my 62/261 truck, but I returned the trans, it was rotten inside (water). I looked iver that project and decided to simplify things a little. Now I have a line in a 93 t5 (1352-216)and with my 3.38 rear and a .86 OD. it sould be pretty good. Am I wrong in assuming that this trans will only require the same massaging as the 83-87 t5's? Its reasonable enough in price and it's a WC? so I can afford to get a speed adapter for it. This will also cure the error created when I went from 3.90 to 3.38. What do you think? | | |
#75720 03/30/2007 10:03 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds ideal too me. I,ve got one in my 58 & had one in a 55. A guy might consider a set of custom gauges. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#75721 04/02/2007 12:59 AM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I think the only problem you may run into is that at some point the T-5s went to electronic speedos, I think '88. If you use a later tranny you would have to use aftermarket guages or spend $200 - $300 dollars for an electrical-mechanical conversion unit.
