1 members (RLB), 77 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#75719 03/30/2007 5:23 PM
Junior Member
Junior Member
Here I go again. I thought I'd try a 2004r behind my 62/261 truck, but I returned the trans, it was rotten inside (water). I looked iver that project and decided to simplify things a little. Now I have a line in a 93 t5 (1352-216)and with my 3.38 rear and a .86 OD. it sould be pretty good. Am I wrong in assuming that this trans will only require the same massaging as the 83-87 t5's? Its reasonable enough in price and it's a WC? so I can afford to get a speed adapter for it. This will also cure the error created when I went from 3.90 to 3.38. What do you think?
#75720 03/30/2007 10:03 PM
Riding in the Passing Lane
Sounds ideal too me. I,ve got one in my 58 & had one in a 55. A guy might consider a set of custom gauges.
1972 Chevy c10 Cheyenne Super
#75721 04/02/2007 12:59 AM
I think the only problem you may run into is that at some point the T-5s went to electronic speedos, I think '88. If you use a later tranny you would have to use aftermarket guages or spend $200 - $300 dollars for an electrical-mechanical conversion unit.
