5 members (Stovebolt48, Rmillerfly, Shaffer's1950, 2 invisible), 93 guests, and 1 robot.
Topics128,050
Posts1,055,758
how the hell do you get the rubber around the windshield. slot is sooooo small, and afraid to use tools due to possibility of chipping.
Ex Hall Monitor
Ex Hall Monitor
If the groove in the rubber is too small to fit the thickness of the glass send the rubber back & buy from a different vendor. I would recommend Steele.
If that isn't the issue you need to be more specific in what exactly your problem is.
slot is wide enough, just hard to get over edge of window.
I used Steele, its still very tight-I ended up taping it in place as I worked it around the glass.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
If possible,after taping the rubber on as 64fleetside mentioned,
leave it for a couple of days for the rubber to take a 'set.'
Basically,If the rubber aint tight it'll leak.
More pix on Flickr.
Moderated by  ndkid275, Phak1
