0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#757009 06/23/2011 8:35 PM
One of the first mods I put on my 57 was 76 Chev pickup power steering. It steers easily, but the turning radius is way too long, and it shimmies on bumps and wanders a bit--all this with all new steering, suspension, and axle components. I am planning to re-install the original steering, and have two questions--can I insert the steering column from the bottom if I remove the headers, and what is the correct term for the bracket which bolts to the spindle and backing plate and receives the front end of the drag link? On the conversion kits it is a Y-shaped bracket. I thought I saved all the parts when I converted, but cannot find this piece, and cannot find it in the service manual or factory assembly manual.
Russell #757014 06/23/2011 8:50 PM
Originally Posted by Russell
..can I insert the steering column from the bottom if I remove the headers...
installation from below is the only way to do it. the steering box which is attached to the column won't fit through the hole in the toeboard to allow installation from above.
Russell #757015 06/23/2011 8:51 PM
Riding in the Passing Lane
Its called a steering arm.
1972 Chevy c10 Cheyenne Super
tomctomc #757045 06/23/2011 10:13 PM
Tom--I didn't expect to put the unit down from the top, but need to know if removing the headers is enough, ie, will I need to pull the engine?
Russell #757083 06/24/2011 12:25 AM
OK - i have a 6 cyl, and I had no problem replacing the column without taking anything off the engine. Do you have a V8?
tomctomc #757122 06/24/2011 3:17 AM
Removed my stock column without removing the engine. Small block. Can't remember if I removed the exhaust manifold. Did the '76 have independent front suspension or was it a straight axle?
orchidskip #757577 06/26/2011 2:15 AM
The 76 was independent suspension. I think 59 was last year for straight axle, but not certain. Most of the power steering kits available from our usual suppliers specify pump and steering box from a 73-87 C10. My engine is a 350 with headers of unknown make-Thorley,Hedman, ??
Glad to hear I won't need to pull the engine
Russell #757652 06/26/2011 12:21 PM
russell,
are you giving up on the power steering ?
after all that hard work i would want to fine tune it and keep the power steering. might be something simple. maybe take it to a front end shop and see what they can find.
by the way, nice truck.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
