| | | Forums66 Topics128,016 Posts1,055,337 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | One of the first mods I put on my 57 was 76 Chev pickup power steering. It steers easily, but the turning radius is way too long, and it shimmies on bumps and wanders a bit--all this with all new steering, suspension, and axle components. I am planning to re-install the original steering, and have two questions--can I insert the steering column from the bottom if I remove the headers, and what is the correct term for the bracket which bolts to the spindle and backing plate and receives the front end of the drag link? On the conversion kits it is a Y-shaped bracket. I thought I saved all the parts when I converted, but cannot find this piece, and cannot find it in the service manual or factory assembly manual. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | ..can I insert the steering column from the bottom if I remove the headers... installation from below is the only way to do it. the steering box which is attached to the column won't fit through the hole in the toeboard to allow installation from above. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its called a steering arm. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | Tom--I didn't expect to put the unit down from the top, but need to know if removing the headers is enough, ie, will I need to pull the engine? | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | OK - i have a 6 cyl, and I had no problem replacing the column without taking anything off the engine. Do you have a V8? | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Removed my stock column without removing the engine. Small block. Can't remember if I removed the exhaust manifold. Did the '76 have independent front suspension or was it a straight axle? | | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | The 76 was independent suspension. I think 59 was last year for straight axle, but not certain. Most of the power steering kits available from our usual suppliers specify pump and steering box from a 73-87 C10. My engine is a 350 with headers of unknown make-Thorley,Hedman, ?? Glad to hear I won't need to pull the engine | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | russell, are you giving up on the power steering ? after all that hard work i would want to fine tune it and keep the power steering. might be something simple. maybe take it to a front end shop and see what they can find. by the way, nice truck.
leonard | | |
