8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL), 100 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
#756083 06/20/2011 4:35 PM
O/T I have a wood working project.Instead of wood filler to fill a crack.Do any of you here think body filler will bond to wood?I know ssaw dust and glue will work,I want to do something different
Boyd
BC52 #756084 06/20/2011 4:42 PM
i think Minwax sells body filler in a tiny can for this purpose for 10X the price...
tomctomc #756157 06/20/2011 10:50 PM
Ex Hall Monitor
Ex Hall Monitor
Body filler should do just fine if the surface is clean and dry. I once used body plastic to patch the front steps of the used car sales office back in the '60s.
Tiny #756201 06/21/2011 1:14 AM
Use fiberglass body filler, "Marglass", "Kitty Hair", etc. they are waterproof. Used it on the pressure treated columns on my back porch 10 yrs ago to fill cracks and splits. Still looks great .
wbrowne #756565 06/22/2011 3:01 AM
Home Depot and Lowes have been selling Bond-O for a long time for this purpose. It's the only filler I use outdoors. One of the big advantages is you can fill and paint the same day.
Harold Wilson
41 Chevy 3/4 Ton
Harold41 #756850 06/23/2011 3:19 AM
The only problem with using bondo or similar on wood is that, once it hardens, its rigid. And wood will always expands and contracts. But, as mentioned above, some folks have had good results, so.... give it a shot wink
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #756901 06/23/2011 6:11 AM
Thanks for the replies.I tried it today.Now time will tell
40casey #756937 06/23/2011 3:03 PM
Ex Hall Monitor
Ex Hall Monitor
I couldn't disagree more. Body plastic is flexible by nature. It has to be to keep from cracking when the metal it's put on expands and contracts. The only time one needs to worry about plastic cracking is when it's put on too thick.
