1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#756707 06/22/2011 4:48 PM
Jack of all trades and a Master of None!
Hi All,
So a buddy of mine was a swapper back in the day, and came across an old Draw-Through Turbo Setup for a V8. Present day he still has it and has no use for it, so he gave it to me. I do not have pictures of it as of today, but I am going to get some this coming weekend. It appears to have all the major components (turbo, carburetor housing, oil line and intake manifold adapter and the exhaust manifold w/ mount for turbo. I think if can get this all hooked up and working, it will look awesome under the Suburbans hood!!
Why would I do this you ask?? I like different and its free.
Thoughts???
My57Suburban
This is the slickest swap I have seen for trucks
EZChassisSwap.com
Awesome. Free is always good. Turbo setups can be very streetable, but also can be a nightmare to set up. Good luck.
Single turbo, or one for each side?
Draw-through meaning the carb is before the turbo? So the air/fuel mixture gets compressed?
What about the wastegate (exhaust side)? Overpressure protection on the air side?
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Single Turbo on passenger side, carb is before the turbo and I believe there is a waste-gate on the exhaust side... Compressed air/fuel mixture venting in the engine bay would be a bad idea, so I do not know what could be done to relieve that issue. I found a picture on the web that gives me a rough idea of how it might look... Looks darn neat...
My57Suburban
EZChassisSwap.com
I'll be watching for photos.
What's your motor?
1965 Chevy C10
stock 350
My57Suburban
EZChassisSwap.com
Bearings and seals on old turbos weren't very good and failed quite often. Before you embark on an engineering nightmare, you need to see if the turbo can still be rebuilt. Even modern turbos fail quite often if they have been out of service for several years. Free can sometimes turn into a bottomless money pit.
Very true Crenwelge, the company that made the turbo was bought out by Turbonetics, so if the turbo is bad i might be able to buy replacement parts. Also it seems to be a standard mounted turbo, so with some measurements and such i could probably find a replacement if need be.
My57Suburban
EZChassisSwap.com
Update-
Here are some pictures of the turbo!
Turbo Pictures Here
My57Suburban
EZChassisSwap.com
57Sub3100 #764181 07/20/2011 10:39 PM
Update-
Found out some great information on this beast today.
1. The name of this kit is a Shelby Spearco Turbo Kit from the late 60's - early 70's.
2. This was an expensive kit back in the day, about 4k for the whole kit.
3. I am missing some parts (nothing I can't fab), but the extras are cooler than crap i.e. water-injection, boost gauge.
4. I found a guy 20mins from me selling his on craigslist for $2500.00 brand new / never been installed on a running engine.
5. This was suppose to be the "Bee's Knees" of turbos back in the day.
I have a great idea of how it gets installed on an engine and I can't wait to get it on. I also found some great pictures of it installed on a long block.
Here are the pictures !!!
My57Suburban
EZChassisSwap.com
The turbine only uses 4 cylinders?
1965 Chevy C10
No, it uses the stock manifold on the driver-side and a crossover pipe is needed to connect both manifolds. All exhaust empties from the back of the turbo.
My57Suburban
EZChassisSwap.com
