2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#756275 06/21/2011 6:11 AM
Not sure where to post this. I've always wanted to rebody a newish truck chasis with a vintage body and among other things, use it as a tow vehicle. Seems I am soon to be getting a donated 3/4 ton '94 GMC Suburban in excellent condition and want to rebody it with an old panel or Suburban. (Haven't aquired the vintage truck yet). Has anyone done such a conversion and have some suggestions for what might be the best fit, etc? I like the pre-advance design panels (art deco?)and the 58/59 Suburbans.
Jack of all trades and a Master of None!
I am in the process of getting the needed parts for such a swap. Here is a link to my thread.
Frame Swap
My57Suburban
This is the slickest swap I have seen for trucks
EZChassisSwap.com
Sir Searchalot
Sir Searchalot
I did this with a 56GMC Suburban, see my pics in gallery. Used the body AND the frame. This is much easier and a better fit for many components. Mine was done 4X4 also. Restomod.
Bartamos, Your pix are not found when I click on the link. REally like to see pix of your project. Looks like just what I had in mind and more.
I'm going to be stuck using the "new" GMC Suburban as the platform for the project as I simply don't have a budget to acquire anything else and it is going to be free. I'm told it runs well and has about 130k miles on it. Was used for family vacations to tow a travel trailer and has been sitting for some years. They just found the title so it shouldn't be long before it's in my hands. Then the fun begins. I'll assess its condition and take some vital statistics, then search for the right vintage body. If I have to shorten the frame then so be it. Shouldn't be too hard to roll the rear end forward and shorten the drive shaft. Of course I know that is a rediculous statement. It's never easy. Anyways, I welcome any ideas/thoughts/opinions/suggestions/criticism/useless blather.
Sir Searchalot
Sir Searchalot
I clicked on the post just above yours (my post) "1956 GMC Carryall 4 X 4" and it took me to my truck pic.??? Don't know why you can't get there.
I would recommend cutting the frame in the middle in a step pattern and moving everything inward. By doing it this way, you keep all stock suspension locations. It is much easier to relocate body mounts versus trying to figure out suspension geometry.
here is a picture of what i mean
Picture of the frame cut
My57Suburban
EZChassisSwap.com
Bartamos, It's the link to your photobucket pix after you click on the link to your stovebolt write up.
'57 Sub,
That's pretty much what I had in mind. When I was just out of high school I worked in a truck shop where we lengthened and shortened the frames of large trucks. We might shorten a frame for a smaller box on a bobtail or stretch a frame on a tractor depending on what was needed. We'd drill and bolt up a channel inside the frame and then weld the seam. Very strong. I emailed the company at EZchasisswap and they email me back. They don't have a kit but invited me to call for a chat. I think I just might do that. Thanks for the tip.
