| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If I remember correctly, there is a plate or plates that have a special shape that go behind the panel. This is an area of stress and on mine it was cracked. I did do some welding there. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is a not so good pic. ...pic... I do have a spare dash. I can take some better pic's tomorrow and trace a template for you. P.M. me if you need something like that | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Pretty common problem Mark, mine is the same way. I see you have the bracket out to weld it back together. I'd weld up the holes in the dash while I was at it and punch a couple of new holes. That's what I'm gonna do with mine when I get the cab off. Sent you a pm bout another matter. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Lay up a couple of thick washers and weld 'er up! | | |
