5 members (Phak1, Hanks custodian, walter74, Charles in CA, baldeagle), 164 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
https://picasaweb.google.com/wmhatfield/Cab#5620487856896891122
https://picasaweb.google.com/wmhatfield/Cab#5620488587209668242
Anyone have shot of what that is supposed to look like?
Should I just weld in some patches?
Mark
If I remember correctly, there is a plate or plates that have a special shape that go behind the panel. This is an area of stress and on mine it was cracked. I did do some welding there.
1951 1 Ton Completed
Yes Fred - this:
https://picasaweb.google.com/wmhatfield/Cab#5620488090625264834
Which is broken at the end that attaches to the firewall! :P I have to figure out what angle that goes back together as well!
Here is a not so good pic.
...pic...
I do have a spare dash.
I can take some better pic's tomorrow and trace a template for you.
P.M. me if you need something like that
Pretty common problem Mark, mine is the same way. I see you have the bracket out to weld it back together. I'd weld up the holes in the dash while I was at it and punch a couple of new holes.
That's what I'm gonna do with mine when I get the cab off.
Sent you a pm bout another matter.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Lay up a couple of thick washers and weld 'er up!
