| | | Forums66 Topics128,141 Posts1,056,488 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | i know this has been asked before, but i will ask again. who makes decent 55-59 Chevy/GMC Suburban/Panel lower patch panels (front lower fender,rockers,between the rocker to the rear wheel,behind the rear wheel opening)?? | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | LMC Trucks dot com Brothers Trucks Tucker Truck Parts Orange County Truck Parts These places carry repair panels for the front half of the trucks i.e fenders, doors, step/rocker. The lower patch panels for the rear quarter panel are a no go, no one makes patch panels (so I've been told) you will have to fab one up or find another parts panel/suburban for the part. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes Rich, no commercial patches for the 5-9 panel body behind the front doors, but the 55-66 stepside fender can supply the molded edge for around the wheel well .... the front fender patches, and step/rocker from all the vendors may take a little massage but are pretty good
Bill | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | Also a fleetside bed side would work (so I've been told). | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the fleet beds are quite different around the wheel openings, all you'd get would be some of the slab-side areas and a bit of rocker, might as well make your own Bill | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | So is it safe to say, the wheel opening from a step side fender and the remaining sheet metal from the front and back of the wheel opening on a fleetside "could" make a burban quarter panel? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | with more slicing and dicing than it'd be worth, aside from the fact scrap fleetbeds are scarce to nonexistant - the bottom part of the fleet body rolls in more than the panel does and most of the rocker edge is slightly wider ... what might be useful off the fleet would be some pieces in front of the wheel opening between the "rocket shape" feature line and the rocker .... the rocker patch sold for the door step supplies the right rocker shape
Bill | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | I am almost tempted to find a good quarter panel and remove it.. then have it molded for making repops. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you'd spend a long time finding a good one, they're all rotten because of the double wall design .... and your temptation would evaporate when you investigated the cost compared to the likelihood of selling more than 5 in 5 years  just have to get out the tools and sheet metal and get at it or hire someone to do so Bill | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | Looks Great! I just need to find a really good body man with a reasonable hourly rate! | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | And one that travels around the country.....
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have rust free quarters in the "parts for sale". NOT NOT NOT Cheap.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | I have rust free quarters in the "parts for sale". NOT NOT NOT Cheap. PM SENT bartamos | | | | | Joined: Aug 2011 Posts: 8 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 8 | are the cameo fiberglass rear quarter panels, such as the ones from classic industrys the same as a fleetside? they sure look like they would fit my '55 chevy suburban second series. if they work i imagine it would cut a bit of weight off my heavy beast. the only part that might not be the same from what i can tell is the rear bottom corners. thanks in advance for any info. -jrsotojr | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | welcome to the shops JR, the fleet/panel side question has been discussed before, the wheel openings are different - short fleet vs panel .... the Cameo sides are likely very similar to the fleet bed and panel quarters, but doubt that they'd match close enough to splice on, and attaching fiberglas to metal never holds up long Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Or you could check the Stovebolt parts for sale.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2011 Posts: 8 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 8 | thanks, i have learned alot especially about fiberglass and metal not mixing. that would have been an expensive lesson. -jrsotojr | | |
