3 members (Shardean, Ponchogl, dt235sd), 92 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#756270 06/21/2011 5:50 AM
1950 3100 was postive gound 12 v.I switch over to negative ground,Battery,coil,ammeter,switch to postive,two 14ga wire on lelf side of ammeter,10ga wire right side.Is this right,the 10ga wire on ammeter was cut by last owner.Do i hook 10 ga wire to ignition switch.Altinator has regulator built in it.Two small wire from altintor feed assories at switch.Were do i hook 10ga wire from altinator.
There is info in the Tech Tips link some of which is provided by Randy Rundle. Search his web site.
http://www.fifthaveinternetgarage.com/
Drew
DrewP #756465 06/21/2011 10:01 PM
simonbolivar, Although you can find a wiring diagram, I think it's worth it to invest in the shop manual for your model truck. Mine was about $25 and I have used the heck out of it! And, you can keep it in the truck with you...Good luck.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
