1 members (Hotrod Lincoln), 75 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#756069 06/20/2011 3:20 PM
Looking to replace my emergency brake system. I'm replacing the cable from ebrake handle under dash to the mid way pivot rod. There are then two cable lines that run directly to each rear brake from this pivot rod. I am looking for these cables. One of them is frozen and locks the brakes left rear brake. Cannot seem to locate them through the catalogs.
I'm not even sure what they are called. Any help or direction on what they are called and where I can get them. thanks john
1964 K10 Fleetside Pickup Truck
No vendor makes the replacement 1s, i have bought a few nos 1s on e-bay. There is 1 on e-bay right now for the 1 from brake handle in cab to mid point on frame.
Inline tube made mine ; just send yours in and they'll match them. Be sure to call ahead and get a job number. They have a web site good luck.
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
I had all of my cables for my k20 made at a local shop that makes hydralic hose and cables. The shop was called componet tech.
I had to replace one of mine (left rear one) got it at NAPA used a spark plug boot to seal it off.
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
Inlinetube.com has them,with pictures.
