0 members (),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Looking to replace my emergency brake system. I'm replacing the cable from ebrake handle under dash to the mid way pivot rod. There are then two cable lines that run directly to each rear brake from this pivot rod. I am looking for these cables. One of them is frozen and locks the brakes left rear brake. Cannot seem to locate them through the catalogs.
I'm not even sure what they are called. Any help or direction on what they are called and where I can get them. thanks john
1964 K10 Fleetside Pickup Truck | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | No vendor makes the replacement 1s, i have bought a few nos 1s on e-bay. There is 1 on e-bay right now for the 1 from brake handle in cab to mid point on frame. | | | | | Joined: Mar 2010 Posts: 76 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 76 | Inline tube made mine ; just send yours in and they'll match them. Be sure to call ahead and get a job number. They have a web site good luck. | | | | | Joined: Dec 2009 Posts: 35 New Guy | | New Guy Joined: Dec 2009 Posts: 35 | I had all of my cables for my k20 made at a local shop that makes hydralic hose and cables. The shop was called componet tech. | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | I had to replace one of mine (left rear one) got it at NAPA used a spark plug boot to seal it off.
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Jan 2010 Posts: 45 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 45 | Inlinetube.com has them,with pictures. | | |
