4 members (elhippie64, Peggy M, JW51, 1955firstseries), 62 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#756173 06/20/2011 11:50 PM
Hello all, I'm thinking of purchasing a 54 3600 dually that has a flat bed on it. If i put single tires on back would a standard 54 bed bolt right on without much trouble?
[Linked Image from i1188.photobucket.com]
gtreasur #756185 06/21/2011 12:14 AM
I didn't know they made 3/4 tons with a dually rear. Are you sure it's not a 1 ton? If's it's a 3600 you can swap out the duallys.
~Jim
BIG CHEVY 3600 #756194 06/21/2011 12:40 AM
I am thinking Yes, but it would have to be a "standard 3600" pick-up bed that is 90" long.
3100 bed is 78" & 3800 bed is 108"...
The 3600 dually is 3608 & 3609 with dual 16" tires
Wheelbase: 3100=116" 3600=125" 3800=137"
I'm sure some of the other guy's will have more, soon
Good Luck!
1954 4400
1954 3800
Jim D.
'41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck
'54 Chevy 3800 Dump........New Truck!
'54 Chevy 4400 flatbed/dump, Gone to my brother-in-law
'13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles
'01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
JD49 #756196 06/21/2011 12:54 AM
If that is true then you will be able to junk the dually and replace it with a standard rear of some variety. Of course you could just pull off a tire from each side.
~Jim
gtreasur #756204 06/21/2011 1:32 AM
Thanks for the info guys
